Is it the blowers that don't work? And is it both the front and the rear? If it's both, it could be an electrical gremlin. Make sure that both motors are getting current if you haven't done that already. If they are, then I would check your motors and see if they are seized up. Both of mine were dead (well, one was close to dead and kept blowing the fuse over and over again). You can pull the rear motor without disconnecting the coolant line.
The front is a bit more pesky because you have to get the metal housing off the truck to get at the motor underneath. But not a big deal. I took mine apart, cleaned them up, and rebuilt them with motors that I know work. Haven't installed them yet because I don't have my truck back from the paint shop.
