- Joined
- Dec 8, 2013
- Threads
- 7
- Messages
- 22
swapped out 4spd on my 79 20r to a 81 5spd L50 I think, put in clutch fork off 81 also put new slave cylinder for it .I can not get it to bleed .clutch disengages about 1/4 " off floor tried switching rod to adjustable one off 4speed still no luck did pump and dump and vacume bleed still no luck clutch worked fine before swap.yes the masters full yes had pedal to floor while opening bleeder, any suggestians appreiciated laying under truck while dw presses clutch looks like its moving full motion ? ive had defective parts new out of box may replace slave again and try master . I don't think geometry of fork is different from year to year ,could b wrong fork? ?btw don't bother doing this if u have 4.10 gears I have 4.38s or 4.56 in my 79- green paint on pinion shaft .green should be 4.38 but counts as 4.56 .buddys 4.10 4 runner wouldn't drive in 5th unless down hill with wind behind him
