78 tp 74 axle
I just swapped out my 74 drum for a 78 disc axle. My problem is the braking power. At full force the cruiser will come to a slow stop. I thought the original MC and booster would provide sufficient stopping power. Was I wrong? Everything (MC and booster) seem to be working fine. Do I need to install a larger MC or booster? I have driven many crusiers with this set up and they could stop on a dime. They did have larger boosters though. My vehicle is a 74 with a recently rebuilt booster. Any thoughts or suggestions
What is the condition of the calipers on the 78 axle that you swapped in?
What size tire are you using?
What is the condition of your rear brakes?
I've done this swap dozens of times even on Pigs and they stop fine, you got something else wrong as Poser is suggesting.....rock hard pedal=no vacuum to booster or bad booster
All the brake components looked good when I installed the axle. The 40 I pulled the axle from had been sitting for some time but everthing still looked good. I'm only running 31's. I will upgrade (35's) as soon as I can figure out what the deal is. The rear brakes are in great shape. Just replace most everything back there. I have a 78 booster I can put on but then I need to move the air filter. Not a big deal but if I don't have to then I would rather not.
Change out the calipers....
Make sure you do not have a pinched or damaged brake line....
What are the condition of the brake hoses?
All hoses were replaced when I put in the axle. Like I said everything seems to be working like it should. At least I think so. Replacing the calipers sounds like a good idea I'll do that this weekend. Are my expectations unrealistic? I figured that I could lock up the tires fairly easy with a disc swap. I had a fj60 with 33's that would easily lock up.
Did you dump the prop valve out of the master? Possible that not enough fluid is getting to the fronts. since the older master was set up to proportion the fluid for drums. Also need a separate prop. valve for the rears.
Prop valve is about 40 bucks for the rears.
taking out the prop valve for the fronts is free.
Might be cheaper than replacing calipers at this point.
Are you talking about residual pressure valves found in drum brake master cylinders, or the rear circuit of the 40 and 55 series Land Cruisers that came with disc brakes? If the residual pressure valve IS NOT removed with a disc brake conversion, it will cause the brakes to drag, and not release/function properly.
I am not aware of a proportioning valve that exists in a four-wheel drum brake system on a FJ-40 Land Cruiser. When disc brakes were introduced in August of 1975, the master cylinder diameter decreased from 1” bore on the drum brake system, to a 7/8” bore, a fixed restriction proportioning valve was mounted under the brake master cylinder on the front of the booster to try and control the rear drum brakes from locking up, because of weight transfer under hard deceleration, and the size of the booster increased significantly, easily doubling in size lengthwise.
I know of many Land Cruisers that are using a drum brake master cylinder and booster assembly with the residual pressure valves removed, working fine in a four-wheel disc brake set up.
Good luck!
:beer:
-Steve
