78 Fj40 Overheating
Taylor, TX
Specs: 1978 FJ40, 2F, pretty much stock.
I got a few miles down the road this morning and steam began billowing from the engine bay. I pulled over and I discovered that I had a busted hose. It was the small hose (approx. 5/8" ID) located right below the lower radiator hose. It appeared to be a simple fix. I replaced the hose and got about another mile or two down the road and my temp gage maxed-out. It had overheated again - I had lots of steam and could hear the coolant boiling inside the radiator. I then replaced the thermostat with an aftermarket one I found locally and it still overheated. I turned the heater on to try to cool things down but it blew cool air. I know this is a major clue but can't seem to get my brain working today. The cruiser has been running fine and has never even hinted at overheating before. I definitely seems like something abruptly failed.
Did you refill the radiator after you replaced the hose?
Probably have air trapped in the cooling system - you need to burp the system.
remove radiator cap (make sure the rad is cool/cold), turn the heater(s) on all the way, raise the fron end of the truck (front wheels on a curb will do), start the engine and get it to operating temp - rev the truck several times once warm, refill the radiator as the air works its way out, put the cap back on and your done.
Also make sure that you replaced both gaskets at the thermostat - there's the manifold gasket and an o-ring that seals the thermostat to the block. If you didn't replace the 0-ring chances are that you'll get coolant bypassing the thermostat and very little heat
Harry
Harry
Everything he said...
The radiator was refilled after I replaced the hose. I read a few older threads about trapped air and burping the system. I guess I'll give that a try. And yes I replaced the gasket and the rubber seal that sits on top of the thermostat.
Well I spoke too soon...
I've driven the cruiser about 70 miles or so since I thought the overheating problem was fixed. The 70 miles consisted of several 5 to 15 mile trips. I got about 8 miles from leaving work and it overheated again. Is it possible I didn't burp it enough? I did notice a stream of steam coming from the engine side of the radiator at about the 11 o'clock position if looking at the radiator shroud from the engine side. Pinhole? I had the heater on full blast and it blew cold right before I pulled over. I'm looking for suggestions before I go back out and try to bring the cruiser home (about 12 miles away).
This all started with a busted hose coming from the bottom of the water pump. What is the root cause???
First, see if the fan jiggles by hand-front to back-if it does the bearings are going.
Second, with the truck running and the radiator cap off, allow the truck to warm up and when the thermostat opens, you should see water flowing in the radiator.
BTW- yer last description does sound like you might have a pinhole also.
I just drove the cruiser back home. According to the odo it was about fifteen miles. The cruiser ran absolutely normal until the last mile. As soon as I slowed down to turn it started to overheat again.
I don't know if this is related but I noticed a slight fluctuation in electrical power while driving back. The ammeter needle was moving back and forth slightly, the blower would speed up and down, the dash lights would dim slightly and the turn signal light wouldn't blink (light stayed on) one time when I was turning. Could all of that water/coolant have gotten some electrical components wet causing this to happen?
The engine is still too hot to test the water pump but the fan felt solid. I couldn't detect any front to back movement.
My problems seem to be compounding!! :confused:
The electrical issue is common on older trucks, thrashed wiring, mine does the same thing. Oveheating can only be caused by a few issues, thermostat-radiator/cap-water pump-fan clutch-fan shroud missing-air intake blockage, timing. Process of elimination will fix it, Has the radiator been rodded out ever? May want to pressure test the cap and the system. Fan clutches can also be an issue.
Are you losing coolant? Does the pinhole account for all of it? Any steam in your exhaust (heaven forbid)?
Does your coolant look "clean and green" or some shade of muddy? Could have corrosion and fouling and poor circulation.
You may still have air in the system and may need to flush the lines....take a water hose, connect it to the radiator line a turn on until you overfill the system.
Your also in Texas, which in December shouldn't be a problem, but you may try running Wetter Water in the Summer. I works great, especially if you are sitting in traffic.
With your heat being intermittant your perfromace being intermittant i.e. some trips are good and some are not, I would think you might want to check the t stat in boiling water to make sure it opens and closes well. Are you positive you purchased the right t stat?
I think a pressure check would be a good idea as well.
I had a similar problem .. took out the t-stat and put it in boiling water and it would not open. New t-stat and gasket and radiator cap.... pullled the front ent up on a very steep hill and burped her again. Cools well now.
Also I use a Raytec infared temperature gun and my gauge reads way high to what the real temp actually is. The gauge always read high and worried me. I read 180* pretty much all the time on the road now but my gauge is nearly pegged. Gotta fix that.
My gauge was causing me way too much grief. Pressure check a good idea as well.
Not sure if this matters but my lower hose has a large spring in it to keep it from collapsing and cutting off coolant flow.
Burp the baby!
Appreciate the "burping" technique...having same problem. I blew a freeze plug due to a stuck thermostat. Napa and Pep boys offered 2 different ranges, both as "stock" but different temp thresholds. Beware of this as a potential issue.
Are the belts tight enough? you know, loose belts, slipping alternator and water pump?
x2 what Grant5127 says. With your electrics flickering sounds like another symptom of a loose belt. Also fan clutch. Sounds like the problem is worse a low speed (fan not turning enough to draw air through the radiator).
Pin hole is a problem that will need to be addressed also.
