76 to 80 ambulance door modification
northern utah
Hi all.. i have a 76 FJ40 that i am fitting a hardtop from an 80 FJ40, including the rear ambulance doors. The top is on with no problem, and the doors are up next. I have heard there is a small mod that i will need to do on the rounded corner of one or both of the doors to get them to fit correctly.
If anyone can help me figure out what is needed i would really appreciate it.
thanks!!
Using 1/79 ambulance doors on a pre 1/79 tub built for ambulance will bolt on find. Just a gap in the lower corners where the door are rounded. Using pre 1/79 ambulance doors on 1/79 tub there is a small interference. Squaring up the corners will seal the doors the lower corners but not needed fit the doors to the tub. Door openings are the same except fort the lower corners.
