76 fuel pump on 79
phat73cruiser said:
My 79 fuel pump is leaking at a small hole on bottom, can the hole be fixed or closed ?
That leak is fuel getting past the diaphragm in the pump, and this fuel is also getting into your engine oil, diluting it. Operating an engine with fuel in the oil for an extended period of time can cause damage to the internal components of the engine because of improper lubrication.
Replace your fuel pump. The return line on your 1979 goes back to the fuel tank. Compare the two fuel pumps side by side, paying attention to the engine block mating surface heights and the fuel pump levers. The fuel pump from the 1976 can work, but make sure that the fuel pump lever that rides on the camshaft is the same length as your 1979, and if your 1979 pump has a spacer on the engine block between the pump, that you remove that and take it into consideration when comparing the pumps mounting heights. If you leave the spacer on there, the 1976 pump lever will not fully seat on the camshaft fuel pump lobe, and will not operate properly.
If your truck is mostly stock, I would just get a 1979 OEM fuel pump and not think about it again for 25 years.
Good luck!
-Steve
