How much grinding needs to be done to the axle to accept a mini birf or longfield. Does anyone have a measurement or can take a measurment with some calipers real quick? Just need to know when to stop with the angle grinder.
I have not measured, but someone else said 25 thousandths. On mine, it was about 20 seconds of grinding top and bottom until the new Lonfields would slip right in. It didn't take much and was much less work than I anticipated.
Unfortunately no Longs in hand at the moment, new gears hit the wallet hard enough for this month, maybe next. Just trying to be ready for the inevitable, and looking for some regular birfs for spares for right now.
I'll go ahead and try around .250" then, thanks much.
Holy s*** batman, not a 1/4". It's probably around 1/32" on top and bottom or ~.062 inches total (about 30 thousands on each side). I'm just guessing though cuz I did the grind fit grind method until it fit.
i did a little bit extra grinding just to make sure that a broken, mared up Birf would come out and a slight variation on a new one would work on the trail.. maybe 1/16th total top and bottom
Cool I think that's about what I ended up with. 1/16' ~ .0625" ~ .028+/- each side. I guess maybe i took just enough that GreenWeeny's BFH should work now, that's plan B at least
