'75 transfer case leak
I have a '75 fj40 that I am rebuilding for the second time. I just put new seals in the transfer case, installed it, but still have a slow leak from the rear output shaft. I can't see how that seal is supposed to do its job when the shaft has splines at the point where the parking brake drum flange passes through the seal, so have I missed something, or is the fluid level supposed to be below the output shaft rather than the side drain plug?
I am very much a mechanical beginner, so any answers need to be pretty free of tech speak. Thanks for any help.
Gord
apply a bead of silicone to the shaft splines before the washer and nut install...
This is a pretty common problem. I have finally cured mine, but it took: getting a new speedo housing from Mudrak that holds two seals, speedisleave on the drum, and I still put the silicone on the splines for good measure. Do a search and you'll find threads and info on all these fixes. I finally have a functional e-brake after ten years.
