75 Series PTO Output - Morita Fire Trucks
Oregon
I’ve got a 94’ HZJ75 Dual Cab with a fire truck conversion (now removed) with retained PTO assembly.
Looking for information on the PTO specifications. I believe the PTO on it is the standard PTO that was offered on a few Toyota Landcruisers. Looking for RPM ranges, HP, instructions etc as it will be married to a hydraulic pump to run equipment.
Thanks
I'd be curious what it had on it too, in North America most fire trucks have a pump driven off a splitter box between the transmission and rear axle because the massive pumps require more power than what transmission PTO can offer. I've got a PTO equipped BJ74 and that thing is small, about the size of a 6 bolt PTO found on an F550.
Just googled it and for this model the specs say 50hp/280ft-lb! Thats a lot, will likely be limited by the size of the whatever shaft it requires.
