Hi Guys,
I was bored yesterday and decided to swap out the igniter coil in my 75 FJ40 with what appeared to be a new coil that came with my car when I purchased it a month ago. After finding that it may not be the correct year (smaller coil, different brackets) I decided to put the old one back on. Initially, this wasn't a big deal as I didn't see too many issues with the old one, I just thought it may start a little easier than it does currently.
After reinstalling the old one, I have encountered a problem. When starting up, it cranks and cranks cranks, never fires/sparks until I pull back the key from "start" to "on". It runs like it did before, it just is more difficult to start.
I thought I got everything rewired as it was before but perhaps I'm wrong. Maybe some of the wiring of the igniter assembly is going bad and pulling everything just brought this to light but I'm stumped.
The blue wire is the one that is perplexing, I originally connected it to the negative pole on the coil and thought, "maybe that's the problem". Then I connected it to the positive pole, no change. I've even disconnected it and had no luck.
I knew I should have taken some quick photos before I started...
Can someone look at these pics and let me know your opinions? Many thanks in advance for the help!
--Rob
--Rob
