'75 axles under a '68
Tenino, Washington
I have a '68 FJ40, I picked up a set of axles from a '75 to swap in (no more course spline inners and ball and claw joints). I'm curious what kind of issues I am going to run into when I start this project.
I have read that there was a pinion flange change between those years. I was wondering if I could just change the driveline yoke to one that has the same pattern (not sure if they changed u-joints), or if I had to swap pinion flanges.
I tried to find if there were any changes in brake line fittings between those years, but haven't had any luck.
Any help would be appreciated, thanks!
As for brake lines, yours probably have the 10mm brake fittings , the easy way to check is go by any auto store and buy the shortest metric break line they have. Everyone uses the 10mm. If they fit you're fine. Very early cruiser had 9mm fitting like many euro applications. Your cruiser is right on the cusp.
I had a 68 with a front coarse spline axle and a rear fine spline. I think toyota just wanted to use up old stock
you could change pinion flange but a better option would be to find the later drive shafts. The early 8mm bolts were notorious for working loose. The '75
had fine thread 10mm. Nearly twice the shear strength plus the finer thread stayed put
Thats good to know, I will have to see if I can track down some later driveshafts
Hmm, I don't know if this was done by the previous owner or if it is stock, but on my '68, I have a brake line running from the frame to the drum on each side, on the '75 axle it has a single line running from the frame to the axle, then it splits to each side, so I will probably have to redo the brake lines it looks like.
if your keeping your 3 speed you need to use the same d shafts 4 speed shafts wont work just change the flanges and they will bolt in fine unless you can come up with a set of 74 3 speed shafts with the large flange good luck
On a friend's 67, we had to change every brake line. The fitting diameter is different, and they don't interchange. I would definitely go for four wheel discs if I was going to that much trouble, he did and used an FJ80 master, works great.
Hmm, had a feeling I might have to do that. I'm hoping to find a complete mini truck front axle pretty soon so I can swap to the mini truck discs before I change axles. For the rear I'm planning on doing discs using Monte Carlo calipers (since I have a wrecked Monte Carlo in my field). What year of FJ80 master did he use?
