Wanted 75 and later 2F (top hat) water pump pulley for (no fan clutch)
Carlstadt New Jersey
  1. 40 Series
Looking for 2F dual water pump pulley for 75 and later models. I believe the bolt hole center should be about 2-1/8". See attached picture.
Thanks,
Dave
$125 plus the ride.
$125 plus the ride.
Mark,
Just a sanity check for a 1977 40. The bolt hole center on the pully should be 2-1/8" if I am correct for the (no fan clutch) 6-3/16 long water pump??
Would you also have the exhaust manifold insulation shield for the front side. Attached is a picture of where mine is missing.
How about the bolts/nuts that mount the transmission brace to the frame in good condition? I believe they are two different lengths. Mine are fairly corroded where the mounts were.
Mark,
Thanks,
Dave
define transmission brace please ?
,i am hunting for the pulley too !
matt
