Parting Out 75-95 Toyota Truck Parts Liquidation New London County Connecticut
Looking for 1980 4x4 pickup RN37 Shortbed fuel tank.any help would be appreciated. Thank, steve
Text my business colleague he should have the 1980 tank in his storage unit 8603261633
Looking for 82ish visor hardware basicly the plastic piece that holds the metal bar so the visor doesnt flop also a rear view mirror for same truck
Looking for the visor hardware plastic piece that bolts to the roof (2) rear view mirrow and the rear sliding window latch for 82 toyota truck
Hello. I have been a Toyota owner for over 8 years and have a build thread over at Pirate4x4.
I am trying to continue my project but I have accumulated too many parts so please help me downsize.
I took too much on and don't want to throw them out because I lost money so put them to good use. Let me know if you're looking for something not listed. I use amazon payments, paypal, etc
$100 pair of Toyota Truck IFS 4X4 AISIN Manual Locking Hubs 86-95 4Runner
Toyota Truck Pickup Pedal Assembly Clutch Brake & Gas PEDAL 84-88 89 4Runner $30
Toyota Truck Heater Core & Box 84-88 89 4Runner $40
Toyota Truck Transmission + Transfer Case W56 4WD Forward Shift 5spd 86-88 mechanical speedo $250
Toyota Truck g54 Transmission + Transfer Case 4WD Forward Shift 5spd 84-89 $280
Toyota Truck Transmission + Transfer Case W56 4WD Forward Shift 5spd 92-95 digital speedo $160 tcase sold
TOYOTA TRUCK 4RUNNER 22R 22RE EXHAUST DOWN PIPE $40
84-88 Toyota Pickup Truck 4runner 22R Air Box
Toyota Truck EMISSION CANISTERS 22R Fed 77740 35260 84-88
OEM 84-88 Small Toyota Emblem OEM 75351 89119 Truck 4 Runner
84-89 TOYOTA 4RUNNER TRUCK PASSENGER DOOR HINGES
Toyota Celica Windshield Wiper Motor OEM 82-85 $25
TOYOTA TRUCK GAS PEDAL 84-89 $10 3 available
84 Toyota Celica Power Steering Reservoir, Hard line and Hose 67941 82-85 $40
84 Toyota Celica GT 22RE Gas tank float, complete
1979-1983 Toyota Truck Hood Latch $15
Toyota Hilux Truck SR5 4wd Instrument Cluster Gauge Panel Speedo Tach 79-81 $50 Round plug
Toyota truck 2wd Manual Steering Box + Mount *Eliminate Power Steer* 84-95 dragrace $50 reduce drivetrain drag increase HP
Toyota Mechanical Fuel Pump for 22r 20r Truck 4Runner Celica $20
82 83 84 85 86 TOYOTA CELICA SUPRA HEATER CORE $30
84 85 86 87 88 TOYOTA PICKUP HEATER CORE STD SPEC $30
1984 Toyota Pickup pedal assembly $20
Toyota Truck 4x4 Front inner wheel well plastic liner panel 84-89 4Runner $20 LH RH
1982-1985 Toyota Celica GT chrome "CELICA" and "GT" logos $25 each
82-85 Toyota Celica/Supra Radio Stereo Pocket Storage Cubby Trim Dash Kit $15
Toyota Truck Front DriveShaft V6 4X4 88-95 90K LOW Miles $40
Toyota Truck Hood Hinges Blue or Red 84-89 Toyota 4Runner $25
84-88 Toyota Truck Windshield Wiper Linkage Mechanism $20
Toyota Pickup Truck Interior Door Molding Blue Grey 84-89 4Runner $30
Toyota Truck Seat Belt Left Passenger Side 84-89 Toyota 4Runner $15
Toyota Truck 22re AC Compressor, Clutch 4Runner Celica Corona No Bracket $35 unknown miles recharge
79-83 Toyota Hilux Pickup Truck Rear Drive Shaft 4x4 SWB Short Bed $80 SOLD russ
1979-1981 Black Toyota Hilux Pickup Grill 4x4 with Emblem $40 SOLD
★Toyota Truck 4.88 8" 4X4 Diff Gears Complete 3rd Member 79-95★ $300 SOLD
84-88 Toyota Truck Door Jamb Blue or Grey Scuff Plates Carpet 89 4Runner $30
★Toyota Truck Windshield Trim Panel Cover Cowl No Rust 84-89 4Runner★ $40
Toyota Truck Power Brake Booster w/ Master Cylinder 4Runner Pickup 84-95 $50
Toyota Truck Windshield Wiper Motor 4Runner 84-89 $20
$40 Toyota Pickup Truck 4Runner Front Drive Shaft 4X4 22R 86-95
$60 Toyota Truck Manual IFS 4x4 Steering Box 86-1995 PS Delete Drag PreRunner SOLD russ
Toyota AM/FM Radio 1423 Pickup Camry 4Runner Celica Supra $10
89-95 Toyota Truck White repainted Tailgate with Blue TOYOTA logo $40
79 80 81 82 83 Toyota Hilux Pickup Truck IC Regulator $20
84-89 Toyota Truck Speedo Cluster Instrument Panel Pickup 4Runner $25
Toyota truck cab side ventilation vents (drivers + passengers) 84-88 $20
★Toyota Truck Instrument Cluster Bezel Grey ★84-89 LED alarm light $40
Toyota Truck Grey Radio Bezel Trim 84-88 Pickup $30
86-88 TOYOTA PICKUP TORSION BARS 68225 68227 $150 Pair comes with female couplings
1975-95 20r 22r 22re TOYOTA OIL PAN 4RUNNER TRUCK 2WD $40
1979-95 20r 22r 22re TOYOTA OIL PAN 4RUNNER TRUCK 4WD $40
82-85 Toyota Celica H/B GT A60 License Plate Garnish $35
★Original Toyota Celica GT Black Grille w/ Toyota Emblem 82-85★ $35
Toyota Hilux Pickup Truck 20R AISIN CARBURETOR, Celica Corona $70
TOYOTA PICKUP DISTRIBUTOR 22RE 86-95 $75 SOLD
Toyota Truck Lower Dash + Heater control panel and cables combo -ac Blue 84-88 $50
Toyota Truck Blue, Grey Dash Trim w/ Dimmer 84-88 $25
Toyota Hilux Front Frame clip 4x4 IFS Delete SAS Truck as pictured, save time! $70
Toyota Pickup 84-88/89 4Runner Blue Front Clip with half the fenderwells $40
84-88 Toyota Truck Tail Light Assembly with 22R tail light harness including wired in trailer hookup and reverse lights $60
$120 Toyota Truck Custom Grill Guard Winch Mount with Chrome Front Bumper 4x4 84-89
84-88 Toyota Truck Side Marker Light Drivers side 89 4Runner $15
84-88 Toyota Truck Side Marker Light Passengers assembly 89 4Runner $15
Toyota Celica Complete Driveshafts + Carrier bearing 82-85 2-Piece $120
$10 Toyota Truck Right Side Fender Blue 84-88 trim for clearance big tire rockcrawl
$10 Toyota Truck Left Side Fender Blue 84-88 trim for clearance big tires rock crawl
$20 Toyota Truck 2wd 84-88 Red Drivers side fender small dent
Toyota Truck Crossmember Trans TCase 4x4 Pickup 4Runner w/ mount $40
84-89 Toyota Truck Ignitor Coil 22R Carbed $70 SOLD
OEM Toyota Hilux 4x4 Power Steering to knuckle arm Drag Link $40
OEM Toyota Hilux 4x4 Sway bar 1979-1985 $50
79-85 Toyota Hilux Steering Knuckle Arms SOLD
79-95 Toyota Truck Power Steering Pump 20r 22r 22RE with bracket pulley $40
OEM 79-85 Toyota Hilux 4x4 Tie rod with Aftermarket Dual Stabilizers + Dual Stabilizer Mount from NWOR $100
Toyota Truck Blue Kick Panel Modified for Speaker, Passenger side $15
Toyota Celica scissor jack and lug nut removal Kit with Genuine Toyota Bag $40
Heater Control Valve Toyota Pickup Truck 1979-1983 $15 SOLD
Heater Control Valve Toyota Celica GT 82-85 $15
Heater Control Valve Toyota Pickup Truck 1984-1988 $15
Toyota Celica/Supra Heater Control & cables 1982-1985 w/ AC $25
Toyota Pickup Truck 4x4 Speedo Cable SWB Single Cab 84-88 $25
Toyota Celica GT 22RE Speedo Cable Auto $25
Toyota Hilux Transfercase/tranny Crossmember with mount $25
Toyota pickup Truck Chrome Stick Shift from a w46/5 spd G $20
Complete Tilt Steering Column w/ steering wheel Toyota Hilux Truck 84-89 w/ Key and Cover $140
Toyota Hilux Door Hinges $15
Toyota Truck Power Brake Booster 4Runner Pickup 84-95 $40
Toyota Hilux MudFlaps 4x4 with TOYOTA Logo 79-83 $70 sold
Toyota Pickup/4Runner Front MudFlaps 4x4 with TOYOTA Logo 84-89 $60
Toyota Truck Seat Belt Drivers Side 84-89 Toyota 4Runner $15
Toyota Truck Middle Seat Belt 84-89 Toyota 4Runner $15
Toyota Truck Complete 88 EFI Intake Hose As Pictured 22RE $40
Toyota Truck 2.4 Timing Chain Cover 22RE $10
1984 TOYOTA CELICA GT STEERING WHEEL HORN CAP $25
Toyota Truck Rear View Mirror Light Gray 84-88 Truck 89 4Runner $25
Toyota Hilux Gas Tank Great shape Carbed 22R 4x2 84-88 $120
Toyota Truck Hood 84-88 Pickup 89 4Runner OEM #54480 $90 SOLD, 2 dented ones available $20 each
Toyota Truck Complete Headlight Assembly Right 84-88 Truck 89 4Runner with cage
Toyota Truck Complete Headlight Assembly Left 84-88 Truck 89 4Runner with cage
79-95 Toyota Truck Power Steering Pump 105,000 Miles 20r 22r 22RE $30
Toyota Truck Great shape Rear Axle housing 4x2 $125
Toyota Truck Alarm System + Wiring Harness MT 4x2 22R 1987 with Functional Alarm, keyfob + Horn $200
Toyota Pickup 4Runner LH RH axle shaft with drum brakes $40
Toyota 2wd Truck Rear 8" Differential + Third Member 4.10:1 79-88 Great Shape $180
84-88 TOYOTA PICKUP REAR LEAF SPRINGS 4WD 1/2 TON sold
Toyota Pickup Heater Box + Core 84-89 94,000 miles
1980 Toyota Hilux Coil + Distributor 20R Pickup Truck $150 $old
Toyota Truck Tinted Rear Window w/ Gasket 84-95 $50 Sold Mike
Toyota Truck 22R Carb + Intake Assembly 83-89 4Runner $140
Some 84-88 p/u interior, exterior
Some 22r engine parts, feel free to ask and I'll look
22RE bare engine block, core, $40 spoken for
22re Crankshaft, used, $40 SOLD, 1 might be available
82-85 Celica AC Condenser $40 SOLD
82-85 Celica starter $30
82-85 Celica alternator $50
located in New London County 06320 Connecticut. Thanks for your time. Pictures will be uploaded. PM me or respond here if you don't see what you're looking for. 9+ year Paypal Member.
Hello Erick561,
Do you have the a pair of doors for 1980 truck, that are not cut up and have the vent windows?
hello sorry I did get your message on eBay and haven't responded yet. I do have a set of doors but they're a little rusty at the bottom from my 80 red plow truck says Precision Landscaping on the side of it but last time I shipped two doors to California I got hit with a $300 surcharge on the shipping label
Hello,
I am looking for a neutral safety switch connector ,harness side.
do you have any to sell thank you
I'm looking for a '75 Fj40 exhaust manifold, would you happen to have one?
