75-77 FJ40 Ignition
Cruiserdrew
On the way there
Sacramento, CA
Distributor and coil/ignitor for the "semi-electronic" ignition found in these years. It came out of a running 2F. The distributor was rebuilt less than 3000 miles ago and has a new cap rotor and points. It has the somewhat desirable advance and retard mechanism so you can set up as you wish. Stock on a 76 is retard. Just so you know, a distributor rebuild is about $100 and eliminates the shaft wobble and inconsistant ignition that most of these trucks have. The distributor clamp was new Toyota OEM last year.
The coil and ignitor were working when pulled. The igniter is Toyota # 89620-60011. It comes complete with the ballast resistor and coil.
$100 for both, and I don't want to split since I know for sure it's a working set.
