74 Instrument Cluster Bulb
Salt Lake City
I replaced all of the bulbs in my instrument cluster today (including the D light) and bought the wrong kind of 74 bubs for all the warning lights on the bottom, they are a little bigger than the stock ones. I can't test them because I accidentally bent my positive battery terminal out of shape beyond repair and can't figure out how to replace the battery cable, but I suspect they will still work perfectly as they sill are making electrical contact with the contact pads, and fit snugly (enough) in the socket. Any other problem with this I should be worrying about?
Amp draw would be my concern with using larger bulbs. Were they LED or incandescent?
Forgot to follow up on this. The bulbs ended up working perfectly. Attached is a comparison picture (stock smaller bulb in black socket, bigger Sylvania bulb in Gray socket)
