'72 rear hatch refresh
Tucson, AZ
just some documentation of how my hatch went together. the parts as they were disassembled - looks like the main mechanism had some better days - a little bent, etc - probably forced open at some point
the main mechanism needed more love - it was pretty bent up. took quite a bit of time to get everything lined up and working smoothly. what I didn't realize was that there should be a torsion spring on the one side to assist keeping the handle closed/ prevent it from rattling. I had some various springs in the garage that after many attempts, was able to fashion one that worked
this should be the last part of this thread: placing the weatherstripping. again, a big thanks to City Racer for this great product.
no kidding, this was scary for me because of the potential mess factor along with the risk of it not adhering to the hatch.
the weatherstrip is a really nice piece: nice soft, supple rubber that fit perfect and is contoured to match the recess of the lower hatch lip
it mostly went on well. I wiped everything down with acetone to clean it, then using the 3m adhesive, put a coat on both the weatherstrip and the door, let them get tacky (which seemed like seconds) and stuck them together. I wasn't confident to do the entire piece at once even with my wife helping so we started at the top, let it set for a few minutes, long enough to hold and then did one side, the other and finely the bottom. seemed like we always had either too much adhesive or too little - big clean ups or going back to add more. no awards to be sure but it's holding - might have to go back and clean up the corners... in the end everything adhered well except for a few small sections which I had to add a little more.
