72 F Engine Noise
Adarcy
Carlsbad, CA
Hi all,
I wanted to see if anyone’s heard a similar noise to this. About half way through the video there is a distinctive click noise, similar to the sound that an ac compressor makes when it engages. It only does this at idle and does not do it under load or when free revving the motor.
72 F motor
Headers, Weber 38, dui disty, new plugs & wires.
Thanks for any help
Andy
Ping? Pre-ignition? 'It sounds like a ball bearing being dropped into a tin can.'
Do you have your idle speed screw too far in to compensate for an excessively closed idle mix screw, or small idle jet? The 38-DGMS should be more than 1/2 turn in from touch-off on the throttle shaft cam. You could be running vacuum to the dissy at idle (by having it in more than 1/2 turn) which causes it to be off regarding spark timing for your rpm and air/fuel mix. You could simply be too lean, and/or you also could have glowing carbon in the combustion chamber that is igniting things too soon.
Finally circling back to this. Thanks for the suggestions on where to look Dizzy.
The idle speed screw was excessively turned in. I was able to tune the speed screw and idle mixture screws to a place where the fj drove better and does not make the noise as much, but its still there. Unfortunately (but fortunate that I went looking i suppose) I found vacuum leaks where the intake manifold meets the head, where the manafre riser meets the intake, and where the riser meets the carb, lol.
I figure i'll sort those leaks out first, then go about tuning the carb. This is a new to me fj that I bought mid may. Always fun figuring out what goodies the PO leaves behind. Not sure what it could be if its persists after sorting the leaks and carb tuning out so its not running lean. Maybe a valve adjustment is needed?
Do many people run this weber 38 carb or is the 32/36 weber (or something else) more appropriate for the F motor?
The 32 / 36 is not recommended for the F or 2F. It has been discouraged for engines larger than 2L. It would be even worse for running at a high elevation. They are not expensive, so it is totally worth figuring out the formula of how to make them work for the Land Cruiser.
You might immediately fill up with higher octane.
Get the vacuum leaks fixed; they will otherwise make an F retire early.
Are you running a vacuum line to the distributor? Can a distributor's centrifugal weights be sticky? Make sure that your spark is where it should be for an idling F.
Once you back off on the idle speed screw, enrich the idle by opening the idle mix screw, but if it is out more than 1.5 turns, then you need bigger idle jets (be really easy finding the bottom of the idle mix screw because you don't want to gall the metal when it seats). Enrichment your of fuel / air mix, higher octane (at least temporarily), a more retarded idle spark, and/or getting rid of the cause of glowing carbon in your combustion chamber will probably fix it.
After quite a bit of summer travel I finally got a chance to work on this again. I opened the gap up on the spark plugs per the dui disty guidelines, put a new gasket between the carb and the riser, and cleaned the carb. Then bench set the carb and retuned the dui distributer. I ended up advancing the disty from where it was and backing out the idle speed screw on the carb. It runs much smoother, no longer has the off idle acceleration hesitation, and no longer makes that "click" noise. It's a whole new vehicle. The previous owner did the Arizona Copperstate Trail 1000 overland tour in this 40. I'm not sure how with the way it was running.
It also had 1/4" wheel spacers in the f/r which were all cracked and broken. Next up is to tackle replacing or fixing the rear brakes. The rear wheel cylinders are bad. I'm debating if they are worth fixing or should I just do a rear disk swap. The front already has the Wildwood disc setup.
Thanks again for the advice. She's back on the road!
Andy
