I have a 71 fj, 3 speed trans. Had a bad throughout bearing replacing with a new Aisin clutch kit. Got the clutch in, trans back in went to adjust the 3 clutch fingers, first one seemed to large of a gap (1/8-1/4) turned the flywheel and noticed one corner of the pressure plate was not pulled in tight to the flywheel. Loosened all of the bolts on the pressure plate tried tapping it. It is only about 1mm holding it popping in place. It won’t move. Is there anyway to get this in place with out pulling the transmission back out?
Thank you any help or suggestions
Steve
Steve
