71 fj40, 350 headers question
Website
www.rockcrawler
what kind of headers do you have that allows room for the steering rod to get to the power steering box? i have shorty hugger headers now, but my power steering box is mounted between the front tire and the frame. which i want to move to the front, between the frame and the bumper. i dont see in the engine compartment where there is enough room. post pics if you have them. thanks.
Im running the Advanced Adapters V8 headers from Specter. They are designed for the stock steering, but Ive laid everything out for the Saginaw conversion, and they clear everything. I'm suprised your blockhuggers wouldnt work. I know several running those and also stock manifolds with no clearance problems for Saginaw steering. Hodag
One of the usual suggestions on a 350 conversion is to offset the engine maybe 3/4" or so to the passenger side. You might be able to "adjust" your motor mounts.
Normal off-set is to driverside so that drive lines (front) clears
Nocents
would converting to the toyota mini truck power steering box be mounted out of the way of hugger headers? i remember seeing a picture of this but i cannot find it now. all the technical links for power steering are on gm or fj55. what years and what kind of 'mini truck' are supposed to be used?
Minitruck steering will clear block huggers and ram's horn. Use Toyota 84-? box with angled adapter bracket. It's okay with 10.50" wide tires or less. If you plan to run 35 x 12.5" or more, go Saginaw.
Nocents
Hate to bump for the sole purpose of eating crow, but that's all this is. :o Having some bad days lately.
ps - Doesn't minitruck refer to late '70s onward pickups, pre-Tacoma? (Probably messed this up too.)
