For those of you with diesel 70's that have a factory fuel prefilter/housing... where is it located?
I don't believe my JDM HZJ79 firetruck has one unless its hidden in an unusual spot that I missed. Its something im interesting in adding provided I can get the part numbers and the parts are available.
Not out consideration would be to add an aftermarket filter base or machine one that I can fit a 2 micron CAT filter on. That would probably be the better option since it is a huge filter by comparison and meant for much more sensitive unit or common-rail filtering needs. Plus those filters are readily available in the States and through volume, would last a long time with the fuel demand of the 1HZ.
Keeping it OEM is also pretty nice...
