7-pin/CDL dash symbol
Austin, TX
I just did the CDL and 7-pin today, it could not have been any easier. Total time took 22 minutes because it was awkward to get at the 7-pin module. I went to test my work and was left puzzled. Everything seemed to work out fine, EXCEPT:
When trans in low and CDL switch depressed, looking to unlock in low, the ABS and CDL dash switches continue to remain illuminated. Is this correct or is the relay not being interupted?
with CDL & pin 7 t-case range is no longer in play,
switch depressed CDL locked
switch released CDL unlocked
so try releasing the switch
had someone else get confused in the same manner recently.
Got it!! For some reason, I was under the assumption that depressing the switch was the activator, i.e.,
Depress while in High: center diff is locked
Depress while in Low: center diff is unlocked
Thanks Raven, now I get it.
since you are not the only there must have been a statement here recently that could be mis interpreted.
