For Sale 6bt Conversion Kit, 80 Series
Status
Not open for further replies.
Ellensburg, WA
Up for sale is a swap kit to put a Dodge 5.9 liter 12-valve 6BT diesel and manual NV4500 4WD 5-speed transmission into a 1993 FZJ80. The installer will need to source the engine, transmission, and alternator (Delco Remy 28SI). This is as close to a turn-key kit as you will find.
I am asking $2,000 + shipping for the whole kit. Not willing to separate. PayPal only. PayPal address must match shipping address.
This is a repost from Will who posted this kit which I purchased and never got around to getting off the ground. I've decided to rebuild my 1FZE instead of installing a 6bt/NV4500 as a replacement. I also never aqcuired the machined NV4500 shaft from him in the process, but overall this kit would allow mostly bolt in setup.
The kit includes:
  • Engine Mounts
  • Transmission Mount to work with OEM crossmember
  • Trans/T-case Adapter plate between NV4500 and HF2AV
  • Throttle Bracket
  • Transfer Case Shifter Bracket
  • Spud shaft or machined NV4500 output shaft to adapt NV4500 output to Toyota t-case input
  • Wiring Harness w/ diesel tach adapter (1993)
  • Power Steering Hose
  • SSOR Accessory Bracket for conventional A/C compressor and Alternator
  • SSOR machined coolant outlet pipe
  • A/C Adapter fittings for use with factory A/C condenser and firewall hardline
  • Sanden heavy duty A/C Compressor
  • Full Toyota OEM manual trans pedal assembly including buckets and hardware
  • "Killer Dowel Pin" kit for 6BT timing gear
  • LarryB's Heavy Duty Fuel Shutoff Solenoid Kit
  • Miscellaneous seals, gaskets, and adapter fittings to complete the swap
Pics to follow
Status
