'68 FJ40 Fuel filter conversion help
Burke, VA
Hi all. I want to replace the glass-bail stock filter I have w/a Purolator disposable unit but am not sure what the best way to go about it would be. I was thinking of lopping off the compression fittings and plugging in the nozzles into the larger rubber hoses and securing them w/a couple hose clamps. I'm new to all this so I'm not sure if this is a good/bad idea and what a better idea would be.
Thanks for any input. Here's a pic of what I'm talking about:
I would keep the OEM glass bowl and replace the filter. They work very well and allow you to see the condition of the fuel as well. They (the filter element) are available from the dealer. I believe the part # is 04234-30010 but you might confirm that first. Don't be a typical PO and hack it up just cause it's $1.50 at trash auto.
now if you were to do it I would think to use that you would have to replace the soft(now hard) oem clear lines. OR, at least find some BSP (not at every store) fittings with a barb and then use a soft line. to the filter. Then your going to need to mount that bad boy so it doesn't flop around. It looks like a mid 80's fj60 fuel filter. The amount of work to do this correctly and not leak gas over shadows an easy element replacement.
STAY OEM :D
I'd say just splice it into the existing gasoline line - upstream of your
existing filter. Cut a piece out of the upstream line, and simply
attach your disposable unit into the two new
ends of the old line. Use hose clamps to secure.
If the existing line diameter doesn't match your disposable, it gets just a bit
more complicated - you'll need some simple adaptors. If that's
the case, just take the filter and a piece of the old line to a
friendly auto parts store. They'll dig up the right adaptors/clamps
for you.
STAY OEM :D
Not PO, been in family since new.
Would love to stay OEM, but this course was suggested to me. Also, when I called my local autoparts dealer, I gave them the Fram # for the filter that's in there currently and they told me that the one pictured above was the Purolator equalivalant. Obviously it's not.
Thanks for the part number, that's probably the route I'll go for now.
B-
I have two filters, one before the fuel pump and a small glass one with replacable element right before the carb.
For the cannister filter I used an oil filter mount from an F engine and drilled out the passageways and tapped for NPT pipe thread. I hope to never change the thing;)
EDIT: NO FRAM!!!!
Ed
Thanks. I just went ahead and ordered the part from a Toyota parts site. Might have to wait a bit longer, but that's ok because it'll give me a chance to take my tank off and get all the gas and whatever else might be in there out.
:eek: hopefully i gave you the right part #. It's listed as an element so I think it's either that or the oil filter and the oil filer is a couple of $ more.
In the future i'd recommend c-dan. The dealers in NOVA are useless for 40's much less a 67-68 when it isn't in the epc.
Good luck and bring that 40 back out here. It'll rust to pieces out there;)
I think the number you gave is the oil filter. Found the fuel filter #(04234-30010) written in my Dad's F engine repair manual.
By c-dan do you mean Cruiser Dan? If so, does he have a website or just contact thru the forum?
I would LOVE to bring the 40 back to CO. Miss it a lot. Have lots of good memories of four-wheelin and camping there while I was growing up...but, alas, I really can't choose my location w/my line of work.
Thanks for the help.
:cheers:
sorry bout that. I figured the smaller filter would cost less, silly me. They are all one one reciept and i didn't mark what was what. I guess I could have looked in my book :rolleyes: I'll make the correcton so it doens't come up in searches.
I buy the other filter from you for the troubles if you can't use it.
