'67 axle design and spline count
Can anyone tell me if the '67 FJ40 axles were the same spline count as later (early-70's) axles? The question is whether a 3rd member from a '67 will fit a mid-70's or so axle.
Thanks!
it can be made to fit....the bolt size for the 67 is smaller for the 10-12 mounting bolts, so those need to be drilled out....and the side gears are coarse spline so you'd need to swap the side gears from the 70's into the 67....
it can be done....but it's a PITA and they are still ~40 year old parts.....
Thanks, the spline count is what I was wondering about (fine spline vs coarse spline), but I didn't know about the mount hole size difference.
Based on that, I'll pass...
