66 fj40 drop out
Pimpin part in SanAntonio TX
Website
www.texas4x4.org
ok I searched but I cant seem to get the answer I'm looking for ... so will a 66 4.10 drop out work im FJ60 axles ??? are the bolt hole bigger or smaller can I drill'em out or should I just keep the 3.70 gears ..
BTW this is a 66 FJ40 FJ60 axle swap with sm420(stockgear)rockbox and 3sp case SOA with 36 ot 38 in tires ...I also have 456's fine spline in my 60(4in and 33's) tow rig ...I thought about putting them in there so I cane have the det in the 40. Do you think the 4.10 corse splin would hold up in a towing 60?? its not going to wheel much when the 40 done?
Thanx in advance Joel
YOu can drill em out larger, get a new pinion flange if you wann use fj60 driveshafts etc..
As far as holding up towing? If your smooth probably for a while.. They'd hold up better on road than off if your running a doubler and 38"s but I've never broken a pinion yet.. I'm sprung under tho not over on all my junk..
The spiders can be swapped so yes they were course pinion and side gears.. But hey, they're free right?
