64 Transfer Shift Housing Question
Pasadena, CA
I would like to go to a direct floor shift for the transfer case. Somewhere along the line a po put a floor shift in for 2wd/4wd selection. The hi/lo is a lever on the dash. My question . To do this I believe I need to change out the shift housing to a direct shift type (per advance adaptors). What I have is pictures below...it doesn't appear to be vacuum nor does it appear to be direct. Any ideas as to what that is and more important can I just source the direct shift housing and bolt it on.
Thanks in advance.
Looks like the factory vacuum shift set up from pre 66 era to me. :meh:
Yes, the direct shift housing will attach to the nose cone in the same location as the vacuum assembly mounts.
