64 fj45 long bed frame
Poorhouse, CT.
I was looking at a 64 fj45 longbed pickup,for cheap. while the body is saveable the frame is toast (could be repaired but it needs a bunch of work) Are there other frames that could be used?
Can a 40 rear section be grafted on the frame and stretched ?
Altering frames needs to be done by a pro but from a 71 chasis and body manual.
So by adding 7 inches to the center and stretching the rear frame moving the spring perch back and all the mounts and bump stops along with what have you it can be done.
BTW "Malch" Thanks for the frame dims
Im Going to look at it again after the snow storm, probably maybe sunday midday.
"Leapingdear" thanks for the offer, If I take the plunge I'll take you up on the offer.
