62 tranny into 91 80?
will a 1989 fj62 transmission work in a 1991 fj80?
Any major differences?
Any good 91 80 tranny's in NE?
:hhmm:
I haven’t done this but from what I have researched;
The pilot bearing holes in the crankshaft are usually different sizes between the two. You will need to keep the 80 Flex plate and maybe torque converter.
The transfer cases between the 2 are not interchange. You will need to keep the 62 split case and convert to part time 4WD. I think I read a post where you can use later mini truck locking hubs for the front end but I’m not sure on this.
Make sure you retain the 80 tranny oil cooler. This was not used on the 62s
Not possible. The housings are different. The 80 series tranny has mounting boss for the t-case shifter. the 62 does not. The 62 case has the output shaft needed to slide all the way through the t-case and have the retaining nut on the back of the t-case. The 80 series case just slides on. The out put shaft on the 80 series is a short stub and does not "clamp" the t-case tot he tranny I think the bolt pattern on the back of the tannys are the same though not certain. I am sure that with enough effort and rebuilding it can be done, but not a bolt in off the bat
thanks for info
seems like what i've found out
seems doable as jcj says by swapping tranny and transfer and going parttimee 4wd but tcase shifter is the issue
I bet the tcase shifter would not be a big deal if you did the tranny and tcase together. Froma 60 series split case the shifter is mounted to the tcase if I remember. All you would have to do is modify the angle the shifter came through the floor. It does not need the boss on the tranny body like the 80 series t case does. Ask the guys in the 60 forum about the tcase shifter. Its been a while since I have been under my 60. But the it does sound like it might work. Not to mention I think the split case Toy box might work too since the tcases are interchangeable beteen the 60 and the 62. :smokin:
Yeah, definatly check with the 60 guys and the 3FE yahoo group if you decide to go with a split case.
I believe one of them has a lower gear set (62 I think).
Also, do a search on McNamara gear (Google & Mud). There are some output shaft wear issues you will want to look for while shopping for a TC.
Cruiserland:
I have a spare '91 80 transmission if your interested. I replaced with a new one. The old one does slip some from 1-2, but good on all the others. Not sure if your into rebuilding, but make an offer, plus shipping to your location. PM if any specific questions are in order. If you need pics, let me know.
Steve
I have one that doesn't slip, but shipping is going to be a pita because it comes with an engine that threw the #5 rod thru the side of the block. I'm holding onto the tcase.
I was hoping to do the exact opposite that you are, my bro's 62 tranny is toast. Good info here, thanks for the post.
