62 TCase In A 95
In my limitied knowledge, there is not an adapter made for this. However, it seems like the you should be able to bolt it up to an early 440 auto... Maybe swap tailshafts on the 440 to the 62's tail? I really wish someone would start playing with these things...
What about a front driveshaft disconnect? I've looked those up, why is the typical price over $500?? :eek:
Brian at ACC Toyota made his own parttime for his 80. Its holdin up to some serious abuse. Were gonna part time my dads 80 as well. Im sure he could do yours too.
Will
Need more info
A case out of an FJ-62 will obviously not bolt up to a FZJ tranny. And I doubt that anyone will ever offer an adapter, I hope somebody would. I have an FJ-80 and I plan on installing an A440F out of a 62 with the 62 split case when the driveline goes back in. But after the FJ-80 I don't think an A440F from a 62 will work with the FZJ, isn't the ECU connected somehow to the tranny in the FZJ? Next will be to put an H55 into the 80. In my FJ-60 the 3FE + H55 work well togther, too bad they nevfer offered the 80s in stick here.
Electronic solenoid control.
Which makes them REALLY cool. only the coolest kids have them.
I would think it would be easiest if one wants a split case to start at the Engine fan and work back...
LS1, 4l60E, split case
LT1, TH400, Split case
4BT. Th400, split case
You get the idea.
As far as I know, they are the same case and tailshaft, but I could be wrong.
