6" lifts, compare & contrast
Whidbey Island, Wa
Well between fixing my rig, getting married, moving across the country, working 60 hours a week and going to school for 15 I haven't actually had much off-road wheel time in the 2 years of ownership. But the few times I have my slee 6 inch lift was very comfortable and capable off-road.
I'd say it would come down to price. Both of those kits are good but slee is more common over here and Christo is always available on the phone and on this forum to answer any questions.
I do like the ability to get a hold of Slee, very refreshing. However, like you mentioned price is important. 4wd Systems 6" is approx. $2000AUD which translates through exchange rates to about 1400US. about 1300 less than slee's and then shipping is a couple hundred but still below Slee.
It seems that slee's kit, gives a more complete replacement to all components, where as the 4wd system's seems less complete as far as contol arms, panhards, double cardan drive shaft.
I don't know if these should all be swapped out, when doing a 6".
I base them on the comprehensiveness of the kit, the availability of support and parts, the community of cruiser brothers that run it, and the common sense of the concept "you get what you pay for".
Christo spends hours each week on here helping his customers, plus he is easily available on the phone and in person.
He gives back to this community, and that is worth a lot in my opinion. The extended control arms are a huge plus. with 6" of lift, you will really want to have replaced control arms, not just for caster, but also for placing the axle back in the center of the wheel well.
go with Slee.
Slee's kit is so much better, you get excellent support and advice. The Slee kit comes w/ the caster correction control arms. There is much discussion on this topic so you can look.
Slee didn't put all the parts in there for padding- if you want a smooth running 6" lift, you will want all that's in there.
The bolt-on kit is not a bad price either. I got the DIY kit and it is a lot of work, not horrible but I'm just saying the bolt-on kit is fair. You can save money on the Slee 6 by going w/ the DIY parts.
No one else even approaches the thought that went into Slee's kit. If you want 6", I think he's the only game.
If you don't care as much about vibrations, steering, etc than there are cheaper options.
cool, appreciate your feedback.
Like you mentioned, slee does seem like more of a complete kit, and they have talked to me on the phone over several questions and been extremely helpful.
Dave
It seems like you realize you are trying compare the prices of apples and oranges. Look at what components are included in the lower priced kit and price out those only those pieces from Slee. See if it is still cheaper to go with the Aussie kit.
The question of what "should" be replaced is really up to the user. Plenty of folks here go cheap and don't replace that stuff and then they deal with the shortcomings. Things to ask yourself...
Is it a daily driver or trail only rig?
Do you prefer working on your truck or do you want to play on trails?
How much time do you want to spend sorting out problems?
How much $$ is your time worth (will the "cheap" kit be cheaper in the end)?
Christo spent/spends a lot of time sorting out issues with his products and created a full kit to save you that time and effort.
You will have to address the drive shafts front and rear..A front DC shaft will be a must, and you will need to get adjustable rear upper control arms and most likely a DC rear driveshaft as well. Then compare prices and in the end, Slee will be better, both in completeness and product support.
I built my 5.5"-6" lift piece by piece to see what I could get away with(out), and in the end I needed everything. And Slee's front control arms will be better in the long run than a mix of correction bushings and plates, or whatever else you can do in cobination. I have mixed and matched it all, from2.5" to 6" lift.
BTW, do not expect the rig with 6" lift to handle perfectly and be 100% free of driveline vibes. You can still go down the freeway at 75, but 60 is much safer.
Already checked on shipping for a 6" and part time kit with hubs from 4WD Systems and they came in at $421 US. So yes more than 200, but not sure exactly how much for just the lift kit.
Definately want a clean, smooth ride. I was leaning towards the DIY.
Also, what are your expectations of a 6" lift, and will you get the "intended use" out of it? It will ride far differently than a stock cruiser.
Have you also factored in the rest of the stuff that goes along with a big mod like this? Like:
Tire size/cost?
Speedo correction?
Lower gearing for a 35"+ tire?
What other aftermarket goodies are you going to run to make a 6" kit ride well ? (lift needs weight, meant and designed to carry the weight of heavy bumpers, winches, armor, gear, etc.) Keep in mind the spring rate is high on a 6" lift, which is needed to keep the heavy cruiser from handling like a slinky.
Should have put all this in the intro but didn't want to be to busy... Obviously everything concerning ride near stock will be out the window, however this will not be a DD.
Goal is 35's or 36's as normal drive tire with full articulation, and then able to clear 38's~40's (trimming included as necessary) at low psi's for deep snow travel w/ minimal articulation. (Huge hunter here, and plan on getting stationed in WA in the next couple of months.)
Will be doing sliders, custom front and rear bumpers and possible exo cage with integrated safari rack. If no exo, I will go with a prefab roof rack. Winches front and rear (or removable and wired to both F & R) and on board air.
Will regear to 5.29's, and possibly snorkel (most likely down the road) and maybe some LED's inside just to round it out:flipoff2:.
Looking to go similar to my buddies 4 Runner.
x2
I've talked with several people who have pieced together kits...and ended up wishing they had gone with Slee's full kit. They've spent nearly as much, and been through much more pain and suffering trying to get it all to work.
LOL, love the Mad Max look. :cheers:
Well if you're going to build an 80 that sounds like it's going to be heavy, exo cage, dual winches and all, then you may want Slee's 6" heavy lift. The Aussie lift may not have heavy enough springs. Also, keep in mind the cost of rear UCA's and drivelines to add to that Aussie kit.
