$550 to replace airbag sensor?! Help
So i went to get my '97 80 series' state inspection done, and they failed me due to the airbag dummy light being on. Being an issue related to the airbag it made me a bit nervous so I begrudgingly took it to the Toyota stealership. They told me for the bargain price of $550 they'd replace the center airbag sensor, gee thanks.
I understand from reading some other posts that the unit they're refering to in on the transmission tunnel / under the radio. I've also seen new OEM sensor units online for $225. I'd really appreciate some help on how to fix this myself, and save the cash for the rear bumper/spare carrier I need. Thanks fellas!
PM CDan (cruiserdan) and see what he can get you the part for cost wise. He is the official MUD parts Shaman :)
Also, either buy or download the FSM.
I believe the sensor is under the shift console cover on the right side in front of (toward the radio) the PWR and 2ND buttons. Has a yellow/orange sticker on it IIRC and says something like speed sensor or deceleration sensor. To remove the console you:
  • Put the parking brake on
  • put the vehicle in neutral (either via turning the key or via the secret release)
  • turn key to off position and remove (don't leave in "on" position)
  • remove two screws on each side of the cover
  • remove the t-case/center diff shift knob
  • lift up gently on the cover and unplug the connector going to the PWR and 2ND buttons
  • guide the cover up and over the shifter by pushing in and holding in the OD button
You'll see the sensor. As for replacing it yourself? With the FSM and following the proceedures I don't see why it can't be done :confused: although working on anything to do with airbags freaks me out.
By the way, do you have any codes (i.e. your Check Engine Light (CEL) is on)? If not you might have just hit the magic 10 year time for checking the airbags and thus the light. I think it is 10 years and then every year or two thereafter for life. I thought I read that the system just needs to be checked and the light reset if no trouble found? For that kind of money I'd probably want a second opinion that the sensor really is bad.
Oh, and welcome :flipoff2: (official MUD welcome)
P.S. Here is a current ongoing thread about resetting the CEL/Airbag light that may help
https://forum.ih8mud.com/showthread.php?t=157278
