55 with Dodge running gear
Hey I found a great deal on a 73 dodge D200. Has V8, 4spd, divorced NP205 and Dana 60s front and rear. Any objections to putting all the running gear in my 71 fj55. Problems I might run into other than the standard parts fab? Only problem I see is the added axel width. Anyone know of fender flares that will fit the 55.
Welcome.
Closed knuckle 60 up front.....no thank you.
19 spline rear 60.......no thank you.
What is wrong with what you are running?
I have only seen those rubber lip type flares on a 55.....ick!
Good luck!
-Steve
If ya want the v8 and np205, you could drop the engine and gearcases in, prob. with some fab. Otherwise, you should just tell me where it is, cause I need a truck to build a buggy outa, and I got a good set of 1ton axles for it...
John
