55 Springs how much
Menlo Park, CA
I can get a set of clean 55 rears, extra leaf was added for $150
Are used 55 springs (in good condition) worth $150????
What would you guys pay?
I'm thinking about putting em on my 40. I'd like a longer wheel base. Also I know that they bolt right in, but I'm assuming you'd have to lengthen the driveshaft right? What else would be involved in doing this?
So far I have: (what else)
Lengthen Drive Shaft
Trim Rear Fender Well ??
Custom Bushings
Longer shackles
Thanks
Price is really up to you. It's higher than what I've seen before, but I'd like a set too and would be willing to pay that.
If you're not moving your rear spring hanger back, you'll need some long rear shackles and I believe you'll need different sized bushings.
You'll also want a rear wrap bar with those long springs.
unfortunatly I'm not a member YET. It's in process so I don't have access to TT yet.
I wouldn't pay that, nor would I buy into the FJ55 rear spring phenomenon just cuz it's "Toyota", that's B.S. They are close to 40 lbs each, so if you don't mind paying shipping or if you're a purist, I have a set I'll let go for a fraction of what that crackhead is asking.... PM me..
You will need to get some custom bushings that Spectre sell. The FJ55 spring eye hole is bigger in the OD and ID. You will have to get a bushing that has the 55 OD but has the cruiser ID for the spring pin. Same with the shackle mount unless you want to run 5/8" bolts like I did.
For the shackle I opted to run a longer shackle instead of moving the shackle mount like Woody did. I am using a 6 1/2" eye to eye shackle to get the 45 degree angle.
Since you hate Purists....Then what springs would you use to give longer wheel base and more flex?? Just curious.
Funny you say that, cause the area the guy is from is known for a lot of Meth Heads.... LOL:grinpimp:
Wouldn't know about old skool leafs as my LC's run coils. Take a tape measure to any truck yards & start checking the lengths for a match. Look for less & thicker leafs in a spring pack compared to the 7 or 8 leafs in the 55 pack.
I'm not a purist as it's half Chevy, but I'll probably go w/ the 55's since it sounds easier and has been done before. Plus I don't really have a shop or garage or the equipment to do fab work. Yes I know there isn't too much fab in swapping springs.
If I had the dime, I'd get some alcan orbit eye springs, had them on my previous rig (91 toy pick-up)and boy did those flex!!!! nice ride too.
