54mm compatible with 2 1/8th socket
Arizona
I cant find a 54mm socket anywhere to tear down my hub to rebuild the axles. Can I use a 2 1/8 th SAE? Just want to make sure before I drop 75 bucks.
You can buy 54mm hub socket from Snapon for $20 shipped ANS1900B, Socket, Axle Nut, 54 mm,
although that is 3/4" drive, you might need adapter unless your ratchet is 3/4" drive.
I believe 2 1/8 should be OK also.
2.125 * 25.4 = 53.975
At $75 I'm assuming that is a large, cast socket: often the walls are too thick to use as a hub socket. Better off getting a true hub socket for under $20. and I think C-Dan sells a Toyota version.
Use only the correct size hub socket, not worth riskin' it.
Sears usually has a 2 1/8" socket 3/4" drive in stock that works perfectly fine on the 80 (and mini, and 40, etc etc). It's under $25. Just used mine this weekend.
yelp, that is what I have/use
works great
That's funny right there- a 2 1/8th socket is within hundredths of an inch of 54 mm, probably within the tolerance for a socket that big.
In any case, I use the 2 1/8th without any issue. Then again, I often use a 9/16ths instead of a 14mm. I'm a rebel that way.
-Spike
there is a thread someplace discussing the various sockets by brand and the issues of being too thick
Without a link it never happened. :flipoff2:
I purchased my 2 1/8th 12-point socket at Sears and used it many times without issue. If I would have had an issue, I'd have returned it immediately, and gone looking for another 2 1/8th socket with thinner walls. That's my advice to the OP if he wants to get on with his job.
I would be willing to bet an entire set of Harbor Freight large sockets, either metric or SAE, could be purchased for close to the price of one name-brand socket. Garbage, yes. Sufficient for 60 ft/lbs? I'd bet on it. So there's another option.
-Spike
-Spike
Whoa dude! Remind me not to drive on the same roads as you.
-Spike
is actually a negligible 1/10000 bigger of an inch if calculated.
Let me add to the voices that tell you the Sears Craftsman 2 1/8 works like it was made for this job, and it's available everywhere even on a Sunday. It's 3/4 drive so you need a 1/2-3/4 drive adapter.
A 55m worked to get it off. I am sure I'll need a 54m to reinstall.
Sears is the way to go. In my case I had to use a 6 foot cheater bar as the Idiot P.O. or his mechanic used locktight. Almost lifted the truck off the jack getting it to break loose.
Not sure if you mean do not use a 2 1/8" socket or do not use a chisel/punch/screwdriver etc. but for every ones edification here are a few pictures:
