5280 ignition timing?
I live in Boulder county Colorado somewhere near 5280 feet above sea level. I want information regarding the correct ignition timing taking in consideration the altitude. I own a 96 with a 1FZ-FE engine. The specs call for 3 degrees BTDC @ 650 rpm in neutral, with a jumper connected between terminals TE1 and E1 of the engine compartment service connector. I appreciate any observations and I thank you in advance.
I was not aware that there was any need to change timing for altitude.
The timing should be set to 3* BTDC to be considered "stock." You can experiment with advancing it +1.. +2... up to maybe +4* (where +4=7* BTDC) You do not need to advance the timing for altitude. FYI, my house is a little over 6,000' above sea level.
-B-
I just adjusted my timing here in CO to 6 degrees in set mode and with the computer in charge its at about 9 degrees. Any more and it started pinging under load with winter 85 octane gas. I noticed a bit of improvement in performance.
I was told for every 1000' increase in elevation, one could increase the timing 1 degree.
Doesn't the 80 call for mid-grade gas? I live in Denver and never use the low grade. Doesn't the higher octance reduce knocking or pinging?
With higher altitude you can get away with lower octane fuel. Now if you are going up I-70 to the tunnel, loaded, on a hot summer day, a trained ear would listen for pinging.
