5 pin rocker switch how to
Utah
Hey! I am trying to wire in all my lights on the new toy. Question is: I need to find the wire that powers my dash light so my rocker switches aren't always on. I have a full wire harness with fuse and relay. Just need to find that one wire to power the switch lights.
That is my question. I don't know if it will pull too much for the size of wire. That would be the easiest for sure since the switch will live right next to it
Just one switch? I "accidentally" tapped my dimmer wire for power to my digital koso gauge. It powered just fine, but ummm had some adverse effects. :doh:. Sinlge switch just for illumination it probably would work fine. I will like the electric gurus chime in, Im not one of them. :lol:
You can certainly tap into the dimmer control to run the illumination for your new rocker switches. Note that Toyota controls dash illumination differently than some other car makers in that one side of all the bulbs is wired to +12v of the tail light circuit and the other side of the bulb goes to the dimmer. So the dimmer varies the resistance to ground to control the intensity of the bulbs. Thus the easiest way to add an additional bulb(s) is to run two wires from the dimmer, one attached to the green dimmer wire and one attached to the white-green dimmer wire.
Illumination circuit:
Thank you all. Wired into the green dimmer switch. Worked great!
