5-pin OEM switch
South Jordan, UT
Yet another switch-wiring post by me...
Dan was kind enough to send me an OEM switch to use with my recently installed AC inverter. It is backlit, with a light that activates when the switch is ON.
5 spades on the backside.
I assume:
2 spades for switching the device.
2 spades for the backlight (is that a hot and a ground?)
1 spade (a ground?) for the activation light.
Anyone have any wisdom to offer?
Thanks.
Hayes
I just did this with a hazard switch.
If you have a volt meter or a current testing device, you can map out the pins by systematically touching each pin in the on and off position. This will give you a clear view of how the pins are related and how you can use your switch.
HTH.
Reid
Would it be alright to use a 9v battery with the circuit tester?
(Apologies if I sound ignorant.)
HTH.
Reid
A simple device such as a 9v battery, a light (flashlight bulb), and a couple of wire leads will work perfectly fine as a circuit tester. Hope that's what you were asking.
If you're talking about one of the "glass fuse" type testers, you'd need a 12v power source to light it.
Reid
