5" OME Comp Kit install, RTH.
Whidbey Island, Wa
So the install has been fairly smooth of the 5" kit from Man A Fre. However, I have just ran into my first snag, either from me being an idiot or them sending me the wrong bolts. I am betting on me being an idiot.
So the question is based on the following kit:80 Series Competition Coil Spring Series Kits.
In both kits you receive bump stop spacers and sway bar drop brackets, based on the info provided in the kit the sway bar drop brackets are the H shaped brackets and I am assuming the bump stop spacers are the 2" round cylinders.
Does that seem correct. From what I understand the front stock bump stop spacers are attached at the top inside the coils, and I am supposed to separate the rubber bump from the steel housing and install the spacer with the bolt they provided to accommodate the additional length. If this is correct the bolt they provided is to big in diameter and will not fit the stock threads. Any insight is appreciated.
Thanks,
Dave
I didn't even install those things.
D
