5.3l Install
Murphy, TX
I am looking at buying the complete powertrain out a '04 4x4 Chevy to swap into my '73 FJ40. The set up includes a 5.3l engine, 4l60e tranny, the transfer case (passenger drop), engine harness, and computer. Are there any other items that I should grab while I am at it? Radiator, driveshafts, electricals, etc? Anybody know of any sites that discuss such a swap in depth?
Chris
Hi Chris-
I would use the search function... Try queeries using the term '5.3l' 'vortec' etc...
Also try www.pirate4x4.com.
I'm also installing a 5.3L (mine's an '07) in a 40 series (HJ-47). If I had to do it over, I would have used the 6L instead. The 5.3L is very tall. It's a tough fit with out lifting your vehicle a fair bit.... Also watch out for the frame rails, steering shaft, and exhaust manifold.. that combination can be a bit tricky.
My $0.02. I am by far not the expert... Other guys on here no a lot more. Pirate has a lot of great tech. I learned most of my stuff by using the search function.
Seth
Chris
Just make sure you get the tranny controller too. I know that it was a seperate box for some of our patrol vehicles. I would jsut get an aftermarket 4 core for the FJ or something that fits the rough dimension. If the yoke end fits the axles your running grab the shafts and just have them cut down. At least you can have somthing to run with till you get beefier ones. And if you go that route then you have trail spares.
Thanks for the advice. I tried using the search function with 5.3l but didn't get much. I figured out after I posted that quotes would help ("5.3"). I plan on lifting the truck 4" so I don't think the height of the engine will be an issue. What did you use to figure out the correct placement of the motor mounts?
Items I wish I had grabbed when I did my 5.3 conversion are O2 sensors (all 4), fuel pump (if low miles), mass airflow sensor, and tranny cooler and lines. These items will just save you money up front. I highly recommend adding the in-tank GM fuel pump. I went through 2 of the inline pumps from BTB products before I did the conversion to the gm.
There is no separate module for the transmission for these years of motors.
I placed my motor as far forward as possible to maximize the rear driveline length.
There is a vortec cruisers user group on yahoo, they should be able to help you out.
I used LS1 edit to do all my computer editing, not cheap but well worth the money compared to paying someone else to do it.
