- Location
- United States
Located in Tuscaloosa, AL
Used Condition
Less than a 1000 highway miles on these tires and 2 mild wheeling trips. The spare tire has never been on the pavement and still has the new little nobbies on it. All (5) have a place on the inner lip of the tire 6-8" long that runs parallel to the tread that is damaged where the dumbass that dismounted them didn't bother to lube the tires. None of the bead seating areas are damaged and should hold air fine according to every non-dumbass tire tech I've showed. The picture is of the worst tire. These would be perfect tires for a set of beadlocks if you are worried about the bead. These tires are sold as is.
Typical tread depth pic
Shipping will be on your nickel ($30-$50/tire depending on location) and I will not separate.
$750
Used Condition
$750
