4x6 projector headlights????
Broken Arrow, OK
I have tried to find some info on this topic and couldn't find any....
I am wondering if anyone has thought of or think this might be possible.
here is what I was looking at a set of (4) 4X6 HID projector headlights. I would like to know if these could somehow be retro fitted to work in the existing grill location after taking the OEM headlights out. This is a long shot type of retro fit but wondered if it was even conceivable to attempt. I guess the safety factors would come into play like where is the cut off with "HID" projector, is there going to be light scatter (on coming traffic) headlight adjustment???? I am sure there are more but just wanted to get some input.
HIR bulbs are also a very real possibility but the look of the stock headlights leaves a lot to be desired. Thanks in advance for the input.
I did mine - just pulled 4x6s out and installed 90mm Hella halogen projectors on H9 bulbs. Can not be happier. Light is awesome and no HID needed.
Link to the aforementioned lights please @Tugarin
I have put both a fxr and a mini h1 in a h6054 h4 conversion housing which I believe was 7x6 housing, and those were both tight fits and I would not recommend their installation for the light hearted esepcially on a smaller housing. Projectors will require cutting of the new housing and gluing back in. My concerns would come from how deep the dimensions are within the new headlight housing. You don't want the projector lens hitting the outer lens of the headlight. Now depending on what is behind the headlight will ultimately determine what you put in. If there isn't much clearance behind the housing you won't be able to recess the projector enough to clear the outer lens with out bumping into stuff behind it. I made this mistake on a 96 tacoma with h4 conversion housings and had to cut part of the air box to fit the back of the headlight.
If you have tons of space behind it then you can put almost whatever projector you want and just cut the headlight housing open more and attach the projector of choice. The only projector I would recommend looking into would be from the retrofit source called the matchbox. It may be small enough for your desired application. I have not used that model personally but have dealt plenty with TRS and their products to say they are top quality. They also have all their product dimensions on the their product profiles and some time with a ruler and caliper gauge can help determine if your desires are even feasible.
As for cutoff, with a projector that is not so much of an issue. The cutoff is clearly visible and where you want to put it when you aim/mount the projectors in. If you need more info let me know and I can try to help explain things. But better if I wasn't clear on anything.
Just for refrence this is that 7x6 housing with a full size fxr projector. Shroud has been cut a lot to fit. I tried to find a picture of the back housing but I don't have any.
You can see on my avatar :) the link is here
Bi-halogen H9 Hella My Hella Lights :: 90mm Bi-Halogen® Premium
And the inner hi-beams H9 My Hella Lights :: 90mm Halogen Headlamp Classic Modules
Hi beams are awesome. Do not go with european version of H7 they do less light output. And plus thet are not so watertight. For RHDs Hella has unique system and all what you need to do is turn the little screw on the back projector and it will become RHD. Having high cut on the left side for low beams.
And that is how it is done on mine.
Hella has 4x6 with integrated projectors bit only for european market. Plus unfortunately due the length they simply do not fit TLC.
Insert, headlight (HELLA , 1BL 005 380-011): Parts - Bestpartstore.co.uk
And they are ONLY LHD and low beams - no bi or high
left side Hella PN 1BL 005 380-011
right side Hella PN 1BL 005 380-021
They have also 7x6
HELLA Insert, headlight Hardened diffusing lens for right-hand traffic DE with low beam Hardened Fitting with adjuster Left with holding frame (1BL 005 740-091) buy cheap online
left side Hella PN 1BL 005 740-091
right side Hella PN 1BL 005 740-101
