4WD shifting and operation
OK, I know this is a pretty retarded question. Bear with me, I am new to FJ40s and they are a different animal compared to Jeeps for sure.
This is a 71. The lever by the heater, what exactly does that control. Is it hi and low? There is a push/pull knob on the dash I believe controls the 4wd as well.
It should be easy to figure out, but it takes some messing around with both controls to get the LC out of 4LO, and I don't believe 4HI is working. Knowing what does what would help me out alot!
Nate
The lever by the heater has 3 transfer case settings: all the way in (forward) is high. All the way out (backward) is low. Middle is neutral, which gets you ready to engage the PTO winch, should you have one.
The knob on the dash activates the vacuum switch for the front-wheel drive cone on the transfer case. In sucks the shift diaphram so that the sleeve slides back and disengages the front drive. Out sucks it so the sleeve slides forward and engages the front drive.
Ideally, there is a plate telling you how to operate these things on the glove box door. If it is missing, they are available.
I'll bet redrustbucket is pretty embarrassed now that he knows he was pulling his lever wrong! :flipoff2:
