4wd question
So yesterday i went wheeling with a friend. We turned the front hubs and put it in 4 low, everything went fine, had a great time. But when i was leaving we turned the hubs back and I drove off with it still in 4 low then about 100 feet later I noticed it and fixed it. Today I went back and was going to do it again and my front wheels werent turning. The front driver side hub was also covered in some type of grease. How do i know if the transfer case is out, or it just needs fluid or what is it?
Your transfercase will operate without oil, in other words it does not run on oil, not to say run it dry.
To check to see if the tcase engaging 4 wheel drive you simply select it with the shifter and then climb under and try to rotate the front dshaft (with the hubs unlocked of course). If it rotates continuously then your transfer case is not engaged inside the gearbox itself. The next thing to check would be the shifter linkages to ensure that the shifting levers are actually moving the shift shafts appropriately. This may require disconnecting the levers and moving the shafts in and out by hand if they appear to not be going in or out all the way. Those linkages get worn out.
Then to check the hubs, just lock both sides and climb under and try to rotate the front dshaft (transfercase in N or 2wd of course). If it rotates continously then at least on hub is not locking, it should only rotate a little (1/8th turn or so) and then lock if your hubs are working properly.
Whew, hope that's what you were even asking.
sounds like i do need to do what you say...i dont know what kind of oil/lube is on the hub. Could it be a bad or clogged vacuum hose like the guy in the other post about his front wheels not engaging?
Yeah, do you have the vacuum actuated selector or lever on the floor? Poser pretty much summed it up in that thread if you do have the vacuum.
It's prolly axle grease and if you grenaded a hub then yes it would be both broken and not working and possibly leaking. But it's not likely that that would be the result of you just driving with it in 4 for a while. I've driven on 4 for many miles unnoticed and never had a problem. Could you have damaged it on an obstacle that day of wheeling, or maybe it was just ready to check out.
The knuckle is filled with grease where the felt/rubber scraper seals, birfield, and hub are. There is a small seal that the axle shaft slides through inside the outer end of the axle tube (prior to the knuckle) that seals the axle 90 weight oil from that greased area. When that seal fails they mix and it gets all messy like mine are right now. :frown:
Check to see if they're locking like I mentioned earlier.
You do realize that there is a search button here for your convenience. It will always yield many more answers much faster than waiting for someone to respond. We're all here to help but you might get what you're looking for faster than having to wait around on us.
Check out some of these threads.
The vacuum shift selector mounts beneath the dash next to the heater if you have one, or you have the floor lever. One or the other. Which is it?
HawkDriver has been apparently usefull in the past and is quite often right on with his testing methods so I would say to get crackin on that. If it's the hubs that would be one thing but if it is the t-case it's even worse.
Also as asked above what type of "grease" was on the hubs: Chassis Grease, Gear Lube? that can come in handy. How to tell the difference: ever repack your bearings before? If so was it more thick and heavy or light and sticky?
