4wd problems
I have a 76 fj40. When I unlock the hubs and shift into 2h the front drive line will still turn when I drive. I have gotten mixed answer saying that this is normal and others say that something is wrong. When in 2h and hubs are in the free postion it feel like it is out of 4wd and it will shift easy into 4h-n-4l.:
Welcome.
Your LOCK OUTS are not working properly.
Likely are packed full of grease, OR, rusted to s*** and not working properly.
:beer:
josh said:
Will it hurt to drive it until I get fixed
It has probably been that way for a while....
Likely not, but it is something that I would address sooner than later.
It is not that big of a deal.
:beer:
Thanks for the info. I am new owner and not much of a mechanic. Is this easy fix or something that i should have done. Also, it accelerates well but feels very tight will this free it up more and make easier to drive around 55mph.
I put the front axle in the air and both wheels spun freely and the front drive was not turning. The transfer case shift with ease and t/shifter slides into the 2h postion. It turns like it is not in 4h but the front drive line still rotates. Also will this hurt the cruiser to drive. Any thoughts?
check the linkage at the t case make sure its not bent at the t case there is a rod with a slot in it on the front cone see if it moves in or out in is 2 wheel drive out is 4 tap it in and see if d shaft turns freely if not have to dig deeper inside thats a whole new explanation hope this helps
