If you have replaced your Toyota 4-wheel Drive emblem, then you may already have discovered that the clips are no longer available.
If you're lucky, your old ones are still good. I had temporarily used a bunch of washers, etc.
Well, this morning I found a near identical and perfect part that even looks like the OEM part (see below taken from SOR):
161-09-U
U RR CLIP-1958-12/78 USED -Availability subject to stock on hand-No return on Used Parts-Used Part NOT Available at this time-Listing for reference only-DO NOT ORDER
SOLUTION:
What I've found works well are the clips that are used to mount the motherboard (mainboard) to the computer's case are PERFECT. ALSO, they are available in metal or plastic. A computer store would likely give them to you. They come in bags full with most computer cases.
I used the metal type. I drill mine over, slightly. Voila! Perfect. They were very much like the originals and quite strong.
Hope this helps someone.
161-09-U
SOLUTION:
I'm sure they will on the 78 too.
