42lb storage deck
Texas
Been working on this for a while. My first generation was 2" taller, had a rougher fit & finish, and had less storage space while being about 3 times heavier. This one is improved in every way with a nice low deck and a weight of 42 lbs.
The large jack box is held up by supports so the tool box can be removed alone.
Each deck panel has aluminum angled stock that is screwed in through 7/16 square steel tube which is snap fastened to the hi-lift bar and latched in place to the main deck structure. Each panel weighs 6 lbs.
The main structure weighs 29lbs completed with fabric and fastening hardware. All plywood used was 7/16 with poplar wood boards for support on the main deck.
The front deck supports hold the hi-lift bar and hold/support the front decking while weighing a 1/2 lb each. The DS main deck bracket is also visible.
Other side. These supports are now painted to match the main deck structure.
One of the deck latches is visible here as well as the wing nut that holds the PS of the main deck to that bracket.
12" sub takes up some space but it is easily removed as is the entire storage unit. Each deck panel gets two deck latches.
2nd row seat hinges were removed. Seats come out easily if ever needed.
The re-profiled 2nd row legs are joined together with 2 grade 8 bolts each.
The final sleep/hauling platform is low, flat, and very sturdy. The tops of the 2nd row seats can be pulled down another inch with bungee cords around the head rest supports, but it isn't necessary with the 5" beauty rest futon mattress. The difference over the folded seats is not felt.
Possible changes may be the addition of one bracket to hold the sub down (it is currently held in place by a bungee and a short 2x4). I hate the idea of drilling holes in my floor.
Another change may be to fasten the main structure through the fabric covered metal brace at the rear. I am hesitant to do this because I like being able to remove the entire unit by removing two wing nuts and I hate the idea of drilling holes in my floor. There is very little flex remaining (only when pulling up on the very rear-none when the tailgate is shut) and I don't think there will ever be a problem.
Looks good! What kind of carpet did you use, and what are some tips for glueing in carpet to make it look nice and professional? I have plans for a box, so I'm looking at lots of home-builts for ideas.
rob
I bought the carpet from Hancock fabrics. It was actually an imitation leather, on the other side, which provided an ideal surface for spray adhesive. I pulled it tight and used a few staples to help keep it tight and wrinkle free.
This is the main deck removed from the supports to be covered with fabric. The edges of the deck will be screwed into the supports making the fabric immovable. One edge is shown in the picture right before it is glued to the deck (spray glue is applied to both surfaces). Few staples were used at the corners to keep everything tight until reassembly.
nice clean build, after doing my own it is nice to see how others are doing theirs.
Thanks, my objectives were a clean stock appearance, better usage of space, less rattling of tools and other stuff, a flat & low deck for my mattress, and lightweight. I plan on throwing up a picture of my mattress, in place, today when I have the chance.
man, nice job! i had a ghetto version idea of this, well, at least using just rubbermaid containers and jimmying a frame around it, and slapping a board over everything. nice!! looks like you can fit two containers length wise? i like the anorexic drill holes too! thanks for the inspiration.
Thanks.
Some of the drill hoes were very long and very challenging. Long screws were needed in many tight places to keep everything solid. The longest screws used are holding the unseen square metal tubing/visible aluminum angle strip to the sides of the 2 front panels. They were 4 inches long-a little longer than their pre-drilled holes.
Here's a picture of the handy lightweight rubber bin during mock-up. A 3rd would fit in the middle if ever needed for some unimaginable reason.
that is alot of whole, and they look evenly spaced. any idea how much weight savings for the time spent?
I saved about 15lbs by cutting the holes, but I wouldn't want to cut all of those holes again. It was a major PIA, but ok for one time. I have thought of others ways to save a similar amount of weight without all of the time spent. The holes in the main support saved the most weight since the main support is two poplar boards joined together. The main support is still stronger than it needs to be and is a place where I know could of saved weight without cutting holes. Still, the two biggest holes are necessary in order to work the middle two latches.
I would say 15lbs would be worth while, seems like building some type of webbed sides could accomplish the same effect, but would probably take just as long.
Here is the Bed Roll ready for travel with plenty of room for pillows.
In the back:
Full size Simmons Beauty Rest futon mattress deployed and ready for sheets. A camo truck cover (not pictured) keeps the light out. Moving blanket, protects the deck when hauling, is sitting on the tailgate.
Comfortable with head or feet at this end.
I have a tent with an SUV sock on the end. It works good allowing plenty of room to unload, stretch, and dress, but I am not entirely satisfied with the hassle of having to erect a tent. It also clashes with my camo greenhouse cover. I am interested in devising a "tent" that easily and quickly fastens in place onto the open tailgate.
wow, i take it comfort is a MUST huh?! a pair of inflatable thermarests will save you lot's of room, but hey, why not?! :D
Tried inflatable. Too firm and fragile.
Space has not been issue, but if it became one I would retire the Beauty Rest for something a little more compact like this memory foam/fiberfill pad combo from Costco (the full size version of course):
Very nice. I plan on implementing some of your weight saving ideas when I build my unit as I'm looking to keep my rig as light as possible.
I have to go now. For some reason I have this weird craving for swiss cheese. :)
Here is a shot at the less accessible space, and an idea of what supports the decks.
This is the bottom side of that panel. I still plan to give the fabric a trim and the wood a little paint, but the fastening hardware can be seen.
