416 paint matches
spicewood,tx.
ok, let's just start here with fact that i have imbibed a few. this may explain the spelling and syntax or not.
just thought i would share some thoughts on #416 paint.
mine is a75 withalmost no rust, just one 3/4 incher. but there is fair amount of surface stuff on the floors. anyway, this my formula.
hand sand the boards with like 100 grit. then mask and spray rustoleum rust reformer. let dry for 24 hours as recommended. after this i sprayed some primer and lightly sanded again. [not sure you need this step, but i had some.]
then only because the next step does not go far, sprayed with krylon camouflage khaki. this does not match # 416 dune beige, but it does make an almost machting primer.
i know im rambling. next and final step, and remember this is on the floor, spray with rustoleom multicolor texured desert bisque. this is a darn close paint to #416, but it has a sand texture to it.
i really like it on boards. will have to wait to see if holds up. all walmart stuff. not bad for country stuff.
anyway, just some thoughts to share. not hard tech.. jim:beer: :)
