40 xfer case options
Fischer, TX
I need a lower low range. What are the best options out there? Can I just do gears in the existing transfer case? It's a 78 2F. Is the 3-speed transfer case weak? I understand it's lower geared...
There's the Advance adapters orion, that you can get in 4:1 or 3:1 for about $1500 or the AA Rock box that comes in a 3.44:1 that fits between your transmission and tcase, it can also be used as an adapter from a chevy 4 speed to the toyota tcase.
http://www.advanceadapters.com/catalog/067.html (Hit back a page on that to see the orion)
Orion- Best bang for your buck keeping your stock four speed.
The lower low range is really negligible with a three-speed case compared to a stock four-speed case. It is not something that I would install in a truck that I wanted lower gearing, thinking that it was going to make a substantial change, since 1.99 vs. 2.313 is not that big of a deal. A later three-speed case is not really that much weaker than a stock case. No one offers gears that can be swapped into a one-piece Land Cruiser transfer case.
Good luck!
-Steve
Orion=swap it out done
Rock box/toybox=replace trannsmission output shaft, cut out rear crossmember,build/buy new crossmember, modify shifting linkage,modify trans hump, new drivelines etc. etc. etc
Been there done both.
One option not mentioned is the SM420, I have no direct experience with doing this mod. But from reading it sounds like it falls somewhere between the two options above in complexity.
It's a piece of cake.
With a stock 4 speed, and a plate adapter, it's 100% bolt in.
NO tranny hump mods.
NO driveshaft mods.
I am running a new old stock SM420, plate adapter, and 4 speed t-case.
I had to make the shifter adapter, and I modified the stock 4 speed shifter (because I didn't like the feel of the SM420 shifter).
NO driveshaft mods.
SM420 + Orion would kick butt.
Well, I am a member, but I don't think I want to buy both an SM420 and a Marlin Crawler 3 speed case.
