40 Tailgate weight
I did the same thing and it worked beautifully. Here's the earlier post:
Well, I searched for a while, tried a few different shocks and finally figured out a solution. I wanted to keep the stock look so I found some gas shocks that fit inside the original lift gate arms. Just remove the original arms, remove the inner springs and misc. hardware and insert the new shocks. Worked like a charm. I shimmed a little on one end to lift the gate about a half inch farther but that was it. I now just pull the handle and watch the gate lift. No more twisting to lock it in place! No more wondering if it's gonna come loose and knock me out! No more wrestling to unscrew the gate once lifted! Problem solved!! I'll try to get some pics posted.
Oh yeah, NAPA part#819-5565
Cooney,
Did you ever get some pics? Sooner or later my '74 hatch is going to need something done and I'd like to be ready for that day...Probably after I wake up from the garage floor after being knocked out by the silly thing :eek:
Cooney, I looked at those and they have a rating of 50 lbs. apiece. seems alittle high. thats why I asked for the weight.
the throw for thoses is also 6.75 in.
I 'm getting some from mcmaster I think i'll get the number to post when they are done.
The gate does not weigh 100#, but I guess it would be better to be a bit strong, then to run right at the limit of a different piece, only to have it fail quicker.
You certainly have enough leverage to close them....
:beer:
According to my calculations, 30# shocks should have worked. I tried 30# and they were too weak. So I tried the 40's. They held the door up but just barely. I think you will find the 50's are best. With the 50's, the door is no harder to close than a Tahoe or something like that. I'm an engineer by trade and did the statics equation to figure out the correct poundage and like a said the 30's should have worked. I guess when you add in the extra friction from placing the gas shocks inside the original chrome tubes it adds up.
As far as the piston length, I tried a couple different lengths in that as well (the guys at Napa hated me in the end). The ones that I listed, worked perfectly. I can only push the gate about a 1/4" past where they lock out. I tried a couple of pair that when closed pushed the piston of the gas shock too far into the cylinder and almost ruined them (the guys at Napa really love when you bring 'em back like that).
Like I said, the ones listed worked perfect for me. I simple unscrewed the fittings on the end and dropped them into the factory cylinders.
I'll work on getting some pics.
