40 Series manual steering gear box
NoCo
1981 40 series with a manual steering box. It was rebuilt about 8 years ago.
Today when I checked the lube I found it had a solid grease lube and not the recommended 90 weight.
So its a what do I do situation? I don’t what to tear it down and scrape the grease out. Do I pump more solid lube into it? Do I pour in 90 wt ?
Thoughts?
The seals aren’t readily available. As a result, many people put grease in them instead of gear oil so it won’t leak out.
If you don’t want to reseal it, add grease if it needs it.
